ologearhead
Nov 17, 2020Tutor
Parental Controls on ORBI RBR850
Is there an update when the top of the line ORBI RBR850 will have Parental Controls?
jsgoecke
Nov 18, 2020Initiate
It is absurd you pay a premium for this product, with a key reason being the use of Circle, only to find out it does not work. And Netgear is silent on it.
This is false advertising, as right on the Circle site from Netgear it clearly states 'Orbi Wifi Systems' and does not make a model distinction like the others. We should be getting updates on this, as this isn't a return, but a potential class action lawsuit.
Jmauser33
Nov 20, 2020Tutor
All I need to know is that they will release the functionality while my kids are still kids. Their silence is frustrating. I'm pissed and feeling litigous, tell me where to sign up.
- DicastDec 17, 2020Initiate
I am growing frustrated by the lack of parental controls as well. I've been using the RBR850 since April 2020 hoping it would get an update that would bring it up to standard netgear offerings. For a top of the line product I can't believe I don't have access to parental controls!
- Jmauser33Dec 18, 2020TutorI ended up returning the router. Eero came out with WiFi 6 on the eero 6pro, and it’s nearly as fast, works with circle, and is 100x easier to manage. Unless you like to spend time on network settings.
- doug0312Mar 03, 2021Guide
does the eero 6pro control PC's connected via Ethernet? both my kids use Ethernet-connected gaming PCs for distance learning and my hope was to be able to use Circle to manage their gaming time. thanks in advance for the help!
