ologearhead
Nov 17, 2020Tutor
Parental Controls on ORBI RBR850
Is there an update when the top of the line ORBI RBR850 will have Parental Controls?
jsgoecke
Nov 18, 2020Initiate
It is absurd you pay a premium for this product, with a key reason being the use of Circle, only to find out it does not work. And Netgear is silent on it.
This is false advertising, as right on the Circle site from Netgear it clearly states 'Orbi Wifi Systems' and does not make a model distinction like the others. We should be getting updates on this, as this isn't a return, but a potential class action lawsuit.
Thador
May 29, 2021Guide
I don't know how NG can afford all of us returning our routers.....parental controls are listed all over the place and then you get home and its "certain models". What crap.
