ChrisJC
Oct 20, 2021Tutor
R6400v2 firmware update breaks Attached Devices and Circle history
After the recent update to firmware V1.0.4.120_10.0.91, the router will not accurately report all connected devices. It only shows 10 devices out of at least 30 that I know are connected. The same is...
bouba1001
Dec 23, 2021Aspirant
Alternative suggestion - I'm noting a difference from the number of announced 'attached devices' icon on the home screen and the listed detail of those attached devices. In my case 16 vs. 5 listed. When logging into my AP (WNDR3700v4) and compare the lists, I'm noting that only the devices with a reported device name are listed by the R6400v2; all those with a device name <Unknown> are not. This in turn leads to a secondary discussion on where the router gets the device name and determines the connection type. My PS4 shows up as wired with a device name on my R6400v2 whereas the WNDR3700v4 doesn't shos a device name but lists it under wireless (which is correct). Go figure.
R6400v2 (V1.0.4.120_10.0.91) as router & WNDR3700v4 (V1.0.2.102) as AP
- ChrisJCDec 23, 2021Tutor
Even after the last firmware update the router is still not reporting usage data to the Circle app. I can't find the dedicated support number for Circle, so I'm not sure what else to do.
- JohnmuledeereDec 27, 2021Tutor
Ver: 1.0.4.122_10.0.95 just downloaded to my R6700V3 and the mismatch between attached and allowed devices was resolved. Issue closed in my mind.
- ChrisJCDec 27, 2021Tutor
Johnmuledeere wrote:Ver: 1.0.4.122_10.0.95 just downloaded to my R6700V3 and the mismatch between attached and allowed devices was resolved. Issue closed in my mind.
What about Circle? Are you using that?
