Circleuser
Jun 15, 2019Aspirant
R8000 with Circle
I use Circle Home app for parental controls with my router R8000. The internet speed is drastically reduced when I use Circle. My internet speed without circle is 300+ MBPS. but with cirle it goes...
DexterJB
Jun 19, 2019NETGEAR Moderator
Hi Circleuser, welcome to the community! We recommend updating to the latest firmware found here and do a factory reset as described here. Also, does the issue persist on all your devices (wired and wireless)? Do you have any QoS features enabled as well?
Dexter
Circleuser
Jun 19, 2019Aspirant
Thanks for the reply. Yes, the firmware is the latest. The QOS is not enabled. But if I disable Circle and restart the router I get 300 + MBPS speed.
- CircleuserJun 19, 2019Aspirant
Yes, the slow down is there on both WiFi and Ethernet connections. Max speed I experienced with circle enabled is around 100 mbps.
Factory reset is done as well. No change in speed.
