Circleuser
Jun 15, 2019Aspirant
R8000 with Circle
I use Circle Home app for parental controls with my router R8000. The internet speed is drastically reduced when I use Circle. My internet speed without circle is 300+ MBPS. but with cirle it goes...
Circleuser
Jun 19, 2019Aspirant
Thanks for the reply. Yes, the firmware is the latest. The QOS is not enabled. But if I disable Circle and restart the router I get 300 + MBPS speed.
Circleuser
Yes, the slow down is there on both WiFi and Ethernet connections. Max speed I experienced with circle enabled is around 100 mbps.
- CircleuserJun 19, 2019Aspirant
Factory reset is done as well. No change in speed.
