GreenYamo
Dec 12, 2017Aspirant
R8000P & Circle
Hi, Online literature seems to suggest that the R8000P supports Circle. I’ve set up my new router but cannot get it to work. Am I missing something? Or is Circle not supported yet? Thanks, Dan.
GreenYamo
Dec 19, 2017Aspirant
Netgear's silence is deafening here.
I've returned the router at this point. I've had issues with the 2.4ghz network dropping unexpectedly. I've also read numerous reports of instability with this router and others.
My previous experience with the R7000p, combined with this router, have put me off Netgear for a while.
- windsagaDec 19, 2017NETGEAR Employee Retired
Hi,
So far, I just can provide android apk and FW for trial use.
Android app 2.0.103 - https://drive.google.com/file/d/0B2EzTtGXuQeFVU1qTE5NOWY4Vzg/view
FW: https://www.dropbox.com/s/jfjzm217az3ggpe/R8000P-V1.3.0.6_1.1.99.chk?dl=0
Just for Circle function trial .......Thanks
- KaiserNGDec 01, 2018Aspirant
windsaga, I would love to test this APK and FW for Circle support, if still available. The link in your post for FW is no longer functional
Hi GreenYamo,
I feel so sorry to got this information.
Did you provide your message and confie file to support team ?
netgearteam@netgear.com
We will support to solve issue undoubtedly.
- DjRiDeJun 07, 2018Apprentice
Is there a beta or timeframe for IOS capabilities?
- DexterJBJun 11, 2018NETGEAR Moderator
Hi DjRiDe,
Welcome to the community!
The links below may help. As it stands, the R8000P is not among the models that support Circle.
https://kb.netgear.com/000044718/
http://www.netgear.com/landings/circle/
Dexter
Community Team
