GreenYamo
Dec 13, 2017Aspirant
R8000P & Circle
Hi, Online literature seems to suggest that the R8000P supports Circle. I’ve set up my new router but cannot get it to work. Am I missing something? Or is Circle not supported yet? Thanks, Dan.
GreenYamo
Dec 19, 2017Aspirant
Netgear's silence is deafening here.
I've returned the router at this point. I've had issues with the 2.4ghz network dropping unexpectedly. I've also read numerous reports of instability with this router and others.
My previous experience with the R7000p, combined with this router, have put me off Netgear for a while.
windsaga
Dec 19, 2017NETGEAR Employee Retired
Hi,
So far, I just can provide android apk and FW for trial use.
Android app 2.0.103 - https://drive.google.com/file/d/0B2EzTtGXuQeFVU1qTE5NOWY4Vzg/view
FW: https://www.dropbox.com/s/jfjzm217az3ggpe/R8000P-V1.3.0.6_1.1.99.chk?dl=0
Just for Circle function trial .......Thanks
- KaiserNGDec 01, 2018Aspirant
windsaga, I would love to test this APK and FW for Circle support, if still available. The link in your post for FW is no longer functional
