orbi-adan
Oct 08, 2021Star
RBK750 Smart Parental Controls Stopped Working (Paid Service)
Used my 30 day free trial for Smart Parental Controls on my Orbi RBK750. Thigs works great for the free trial. Decided to pay for the serives and recently noticed that it's no longer doing anything. ...
- Oct 14, 2021
That looks correct! You do the soft factory reset on the same page that you do the backup. When logged in you go to the Advanced Tab. Under Administration there is a link for Backup Settings. This is where you save a copy of current settings assuming you have made modifications and this is also where you Revert to Factory Default settings for the soft reset. I am attaching a picture of what the screen looks like. Good luck and let me know if it works for you! If it does I will likely switch my configuration around to make the 750 my primary router and the RBR50 as an access point. When I first bought the RBK753 there were no parental controls on it.
Jamieerickson
Oct 09, 2021Tutor
Same issue here. I've been trying to get netgear to figure it out.
- orbi-adanOct 11, 2021StarCan you please post here if NETGEAR give you a solution?
Man have had so many issues is my Orbi- JamieericksonOct 11, 2021TutorI sure can.....if I ever get one. I've emailed, them, tweeted them, sent them Facebook message...lots of avenues to bother them so hopefully something gets solved.
