kkbb850
Aug 15, 2020Follower
RBR850/Circle parental app compatibility
I recently purchased the RBR850 thinking it would be compatible with the Circle parental control app only to find that there is no way to set it up with this system. I purposely bought what I thought ...
CrimpOn
Aug 15, 2020Guru - Experienced User
I think you are correct. This product does not appear to include Disney Circle. Notice that the Product Data Sheet touts the including of Bitdefender Armor, but makes no mention of parental controls.
https://www.netgear.com/images/datasheet/orbi/RBK852.pdf
You might check the community forus for Circle: https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
and the AX product: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Maybe a user on one of those forums has an opinion of when (or if) Circle will become available on the AX product line.
Or... send it back.
