kkbb850
Aug 15, 2020Follower
RBR850/Circle parental app compatibility
I recently purchased the RBR850 thinking it would be compatible with the Circle parental control app only to find that there is no way to set it up with this system. I purposely bought what I thought ...
pvonnetwork
Feb 03, 2021Star
Add me to the list of users looking for Circle app to be natively supported on an Orbi Router RBR850. I would think a $700 product like this would have parental controls.
Christian_R
Apr 23, 2021NETGEAR Employee Retired
Hello NETGEAR Community,
Thanks for expressing interest in a Parental Controls service from NETGEAR. We are excited to share that we have been working on a new and improved NETGEAR Smart Parental Controls solution for the Orbi RBK750 and RBK850 Series and are aiming to have it ready for launch in the next few months! Please stay tuned for an update from us.
Christian
- ologearheadApr 23, 2021TutorHi Christian
What about RBR850? Will the update to the RBK apply to the RBR? I wasn’t able to return it as I discarded the packaging. If only option for parental controls is RBK, I would be open to having it switched out for the RBK to resolve this issue. I purchased the RBR850 because it said it had parental controls and discarded packaging material because of my confidence in the products Netgear made. I have definitely learned a lesson.- CrimpOnApr 23, 2021Guru - Experienced User
ologearhead wrote:
Hi Christian
What about RBR850? Will the update to the RBK apply to the RBR? I wasn’t able to return it as I discarded the packaging. If only option for parental controls is RBK, I would be open to having it switched out for the RBK to resolve this issue. I purchased the RBR850 because it said it had parental controls and discarded packaging material because of my confidence in the products Netgear made. I have definitely learned a lesson.This is a semantic issue. "RBK" is the part number for a package containing router (RBS) and one or more satellites (RBS). This implies that the new Parental Controls product is supported on the RBx750 and RBx850 product lines.
- KabritoJul 11, 2021Aspirant
Hi - Any update on the firmware update to get Circle native on the RBR 850?
Christian_R wrote:Hello NETGEAR Community,
Christian
