inteller
Jan 19, 2019Apprentice
Data drops with Circle enabled on Orbi
When I enabled Circle and moved certain constant data devices as "unmanaged" these devices continue to drop data. Unmanged devices should have no filtering or restrictions through Circle. One impor...
Jeremyinsf
Feb 06, 2019Apprentice
I am a bit behind with posting updates on my testing, but, I can confirm that the issue seems 'better' on the new beta but I still encounter it from time to time. While on the beta my router started rebooting regularly/randomly so I reverted away from it for now.
Overall, it does seem like a better build as many items are corrected. I put up a long post about that in another thread. I don't think Armor provides enough value to actually charge for it though. Also it's still buggy so the one thing that was identified as a concern on my network - it had zero information on.
Jeremyinsf
Also yes, agreed, there were no release notes even when we were told that we would get them, and it seems that there is little engagement with reported issues.
- intellerFeb 16, 2019Apprentice
oh they want to engage, they slither into my DMs and want me to beta test junk. I will not be a beta tester on something that should already work!
- intellerMar 24, 2019Apprentice
so no improvement with new firmware 2.30.0.28. You enable Circle and within 15 minutes or so my IOT device starts to drop communication and eventually knocks offline.
Back to the drawing board boys and girls....
- intellerApr 30, 2019Apprentice
AAAAAAND.....still not fixed with 2.3.1.48...
- ZacksApr 30, 2019Aspirant
I. Also experiencing this issue. I have firmware 23148. I turned off circle and still have the issue. Do I also need to reboot or go through a new setup to completely disable?
- The_CurlyMay 06, 2019Aspirant
I have the same issue when Circle is enabled.Without Circle, no dropping of the wifi anymore. Although it works as a temperary workaround, this is not a fix!
- intellerMay 06, 2019ApprenticeIt isnt dropping wifi, it is dropping requests that unmanaged devices are trying to make.
And STOP messaging me netgear! I WILL NOT be your product tester/fixer! I PAY you to figure these things out! Fix this junk! - The_CurlyMay 06, 2019Aspirant
It is happening for both managed and unmanaged devices for me, not sure what it is doing but no device can access the internet anymore when the issue occurs. It does restore after some minutes.
