edu2023
Dec 31, 2023Aspirant
Reset Circle 1st Gen
Same for me
Jan 01, 2024Guru - Experienced User
edu2023
Jan 03, 2024Aspirant
I had already read this link. I don’t receive the SMS, and without the SMS the only solution indicated in this link is resetting the router and installing everything again (satelites, setting up profiles etc). I really don’t want to factory reset. As per the messages in this topic there is a possibility to get the code sent by an admin
- FURRYe38Jan 03, 2024Guru - Experienced User
You'll need to make contact with NG support for there help. Any codes needed will need to be sent by NG. All this is beyond forum help.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".Good Luck.
