ukdavo
Apr 26, 2020Aspirant
Reset Circle Passcode
I've recently installed the Circle app for a RBK53 Orbi network. Unfortunately one of the kids has subsequently removed the app from my phone (don't ask...). I reinstalled the app & tried the join th...
BMcLaugh
Apr 29, 2020Aspirant
I have exactly the same issue as person who posted this previously. I had to reset my Orbi router, but Circle app got deleted, so I can't obtain the passcode and everytime I try to have a text sent to me, 1 of 2 things happens: 1) the a text message comes through that says there was an "error sending the text", OR 2) I get an error message that says "Something went wrong, Please wait a few minutes and try again", but no text comes through. Clearly need a reset. Would appreciate if someone could reach out to me to assist with the reset? Thanks.
Christian_R
Apr 30, 2020NETGEAR Employee Retired
Hi BMcLaugh,
If you can provide me the following info I mentioned above in a private message I can validate and retrieve the passcode from our system. If you're referring to a reset of your Orbi router you may hold down on the reset button located on the back for 15+ seconds using a pin.
Christian
