Hjer
Aug 15, 2020Follower
Resetting Circle Admin Passcode
I set up Circle on NetGear from an old phone number that I no longer have access to, so I am not getting the reset passcode. There are tons of the same types of posts in this Community, but the solv...
- Aug 20, 2020
Hello Hjer,
I will need the following info so that I can validate and retrieve the passcode from our system. Please send me the requested info in a private message.
Name:
Email:
Model Number:
Serial Number:
Thanks,
Christian
Christian_R
Aug 20, 2020NETGEAR Employee Retired
Hello Hjer,
Name:
Email:
Model Number:
Serial Number:
Thanks,
Christian
Seana85
Nov 28, 2020Aspirant
I've done exactly this 2 times now and I still get no response whats up with that?
- NestastarNov 30, 2020AspirantHello seana, I see your message today, just know that : “I try to resolve the problem with multiple test, reset, code from support. It’s always the same”. at a moment you must reset the router the same (poor programmer ). It’ unstable and your router is very slow. The functionality for paid application are wrong. I just reset last Friday to test another time, and for two days I use the router without this both the route is running very well ( not slow, disconnection, ... nothing. Very nice. Use another software for the parentale control and don’t install Bightwank all contrôle are in the interface of the router . But if you are an IT men like me and you do some night without sleep to try to resolve this issue, I see that last Friday in same time the router is compatible with open source firmware....
- NestastarNov 30, 2020AspirantOr not.... very wrong
