Wwwis
Sep 17, 2023Aspirant
Resetting Circle Pin for Nighthawk R8000
Hi, Can somebody help me reset a pin on the Netgear Circle App? Evetime I go to Manage Circle > Send Passcode > Text Me, I have never received a text message with a new pin. I've toggled Circle on...
Sep 17, 2023Guru - Experienced User
Wwwis
Thanks for send the link, but I've already gone through the steps with no luck, including trying to setup Cirlce on another device.
I've seen a few posts where the pin can be reset by Netgear support.
- FURRYe38Sep 18, 2023Guru - Experienced User
You'll need to contact support. This is beyond forum help.
