BGA
Nov 11, 2021Aspirant
Teen get around Orbi RBR40 with Circle Parental Control App
I've set up Circle Parental Control on my Orbi Router. However, my teen can simply force stop the Circle App, look at whatever he wants and then restart the app. I can find no way to prevent this or...
- Nov 11, 2021
Teens are a challenge.
with enough motivation, they can basically get around most things.
Disable the wifi? They get on the neighbors, use the lte data, or setup a wireless connection to a laptop/pc with data.
Setup parental controls, they tunnel through with a vpn
Setup an app for blocking, they disable the app.
If they're motivated enough, there's ways around pretty much anything.
At a certain point, when they're advanced enough to get around your restrictions, its more about talking to them about why you're restricting certain things and put consequences for their actions.
If their disabling it, its because they're doing something you disapprove of and they're aware of it. Its a conscious decision. Disable the app to get around it? suddenly you get a flip phone to use and not a smart phone. Then they still have access to calls/texts for emergencies. Most phones you can simply swap a sim card around.
I'm not sure what to tell you when your teen gets advanced enough to start working around your blocks other than its time for a conversation about consequences.
Nov 11, 2021Guru - Experienced User
