Noche
Aug 08, 2019Follower
The R6080 has disney circle?
Hello, before buying the R6080 router I would like to know if it is compatible with disney circle. How is the system I have to buy another electronic device apart from the router? Or is the router en...
DexterJB
Aug 08, 2019NETGEAR Moderator
Hi Noche, welcome to the community! You can check the link below for routers that do support the Circle feature.
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
Dexter
