boodad
Apr 05, 2021Tutor
Unable to find Circle. RBR20 iphone and ipad
Earlier today Circle stopped working on my network. Every device that had the app, 2 iphones and an ipad all got the same message "Unable to find Circle" Try Again or Pair new Circle If I choose Tr...
- Apr 07, 2021
Hi boodad,
Thank you for confirming. May you revert to the previous firmware version below and let me know if your issue persists.
https://kb.netgear.com/000062432/RBR20-Firmware-Version-2-6-1-36
Christian
2oldforthis
Apr 15, 2021Initiate
This is happening to me as well. My router is AC1750/R6400v2. The Circle 1st Gen App was working fine then yesterday it says, "Unable to find Circle". Try to pair new Circle then "Darn, couldn't find router". How do I fix this?
- 2oldforthisApr 15, 2021Initiate
Just found the issue!! In settings on my phone, the Circle App was set to Cell Data instead of Local Network. I guess if you open the app away from home network, it must switch automatically? All this tech junk is taking years off my life...
