kjasty
Feb 02, 2022Follower
Unable to setup Circle 1st gen on Orbi RBR50
Trying to setup Circle 1st gen. When I try to login to my netgear router from the Circle App, I am getting the following error - "Something wnet wrong - Please try again to enable Circle" I can lo...
Feb 03, 2022Guru - Experienced User
I would review these:
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
https://kb.netgear.com/000062988/Why-can-t-I-see-the-NETGEAR-Smart-Parental-Controls-tile-in-the-Orbi-or-Nighthawk-app-after-upgrading-to-the-latest-firmware
I saw one user that mentioned he reverted his RBR back to v104 I believe, long enough to get Circle running, then I think he re-updated back to current version as a work around.
