a2cube
Oct 28, 2020Follower
Usage and History not showing
About two weeks ago, the usage and history information has stopped showing in the app. Any suggestions on what is wrong and how to fix it? Thank you.
WeNeedMorePower
May 27, 2021Aspirant
Same issue here. I've been using the Circle successfully for a while now. The last couple of months I've had issues with the usage history stopping and always showing zero. Everything else works (pausing accounts, asigning devices. etc). I've reset the Circle in the app and then it worked for a few weeks. It stopped again so I reset the Circle again. This time it lasted 6 days. Now I've reset the Circle several times and it still isn't working at all as far as tracking usage. All profiles always show zero usage. All firmware is up to date. The App is up to date.
