luisng10
Sep 09, 2019Aspirant
Why it is so difficult to add parental control my god?
Why is so difficult to add parental control. I have spend hours doing this. When click on the parent control tab in the routerlogin.net it take to the stupid circle parental page. I downloaded the a...
DexterJB
Sep 09, 2019NETGEAR Moderator
Hi luisng10, welcome to the community! May we know the model number and firmware version of your router? Also, please try using another device and check if the issue will persist.
Dexter
luisng10
Sep 10, 2019Aspirant
Router R6700v2
I do not think trying from different device will make any difference. I access
http://routerlogin.net/ then select aprental control and it take me to the netgear website for the circle disney parental control.. So not sure how I can set up the parental control on this router..
