luisng10
Sep 09, 2019Aspirant
Why it is so difficult to add parental control my god?
Why is so difficult to add parental control. I have spend hours doing this. When click on the parent control tab in the routerlogin.net it take to the stupid circle parental page. I downloaded the a...
luisng10
Sep 10, 2019Aspirant
Router R6700v2
I do not think trying from different device will make any difference. I access
http://routerlogin.net/ then select aprental control and it take me to the netgear website for the circle disney parental control.. So not sure how I can set up the parental control on this router..
DexterJB
Sep 12, 2019NETGEAR Moderator
- luisng10Sep 12, 2019Aspirant
Sorry but did not recevie any message. Could you please write a solution how to fix it here, if you can offcourse..
