jjpank
Sep 02, 2020Tutor
Why No Circle for RBR750 or other Wifi6 Routers??
I've had my RBR750 for months now, and there still is no word on an implementation of the Circle app for it. It was an expensive router, and i thought it would come with that feature right out of th...
mleasure
Dec 23, 2020Initiate
First of all, you can't even find the RBR750 on the Model menu for this forum. That may tell you something right there. Second, I have been trying to connect my Orbi RBR750 to the circle app only to find out that this very expensive unit is not supported. Looks like no one is even replying from Netgear, which is a HUGE customer service issue and tells me they don't really care about support. Maybe they want the extra $10/month form the other circle app as a $$ generator and don't want to have to address why this doesn't come with the router. I bought this at Costco and will return becuse if there is one thing I hate, it's poor customer service.
giantsuper
Dec 28, 2020Initiate
I am very happy with the performance of this router (AX4200) and VERY disappointed that it has no supported parental controls. Coming from a Nest WIFI which had very simple and intuitive controls, this is a huge disappointment and would like to know when Netgear plans to support parental controls. Parental controls on a modern WIFI router is table stakes at this point and I'm in disbelief that it is not part of the package.
- SergeLDec 28, 2020Apprentice
I've ordered Circles Home Plus, tired waiting for Netgear to enable this feature by default, will see how it goes. Maybe this is the plan all along to force people to buy extra piece of equipment?
- SergeLDec 31, 2020Apprentice
I've recieved Circles Home Plus, it's absolute garbage, cannot properly detect network traffic and block activities on the network. I'm very disappointed.
- vijay05Jan 17, 2021Guide
Guess, it does not really matter to Netgear what customer really needs as long as they have folks keep buying this expensive paperweight.
- VanderMeideFamJul 29, 2021Aspirant
Can you tell me how the Circle Plus worked with your router? I am needing parental controls and am looking at buying this router... though I really wish Netgear just had circle installed.
- dtayJul 29, 2021Luminary
VanderMeideFam wrote:Can you tell me how the Circle Plus worked with your router? I am needing parental controls and am looking at buying this router... though I really wish Netgear just had circle installed.
Circle Plus works with the Orbi 6 AX series, but with a caveat and some limitations. For instance, you have to run it in the "compatibility mode" instead of the standard mode. The downside? Your internet speed for the clients connected/managed on Circle are now throttled down to just 100 Mbps. So, if you have fast internet connection like FiOS, etc., you'll only get 100 Mbps. That, to me, is a pretty significant downside.
https://support.meetcircle.com/hc/en-us/articles/360028507711-Using-Compatibility-Mode
There are some issues (not sure if it's Circle or interoperability or compatibility issues with Orbi AX in general) but sometimes all internet traffic would just halt; I'd have to restart or reboot Circle to get everything connected again.
I'm also anxiously waiting for Netgear to offer an integrated solution - be it Circle or something else - with their Orbi AX Wi-Fi 6 mesh routers. It's a disgrace that at this price point, it's missing something as simple as parental controls.
