jjpank
Sep 02, 2020Tutor
Why No Circle for RBR750 or other Wifi6 Routers??
I've had my RBR750 for months now, and there still is no word on an implementation of the Circle app for it. It was an expensive router, and i thought it would come with that feature right out of th...
adesantiago
May 28, 2021Initiate
Just bought and set up my RBR750. I could not believe it doesn’t have Parental Controls or a way to use Circle 1st Gen. Spent $500 so that I could get the best of both worlds, but nope. Great performance but not worth $500 for just a router. Over a year of complaints and silence or false promises from NG. Unfortunately I will be returning it tomorrow and get something with decent Parental Control.
svusa
Jun 07, 2021Initiate
I agree with you completly. $500 router and no parent control. I can not believe it.... I'm returning it back to Costco tomorrow. NETGEAR if you are reading this, get the damn parent control on the wifi router. We all have grown up now and have kids.
- FURRYe38Jun 08, 2021Guru - Experienced User
Good luck then.
