Marcvane86
Dec 20, 2021Aspirant
WiFi calling issues / RBK50+2*RBS50 setup / IPSec
I Can't Get WiFi Calling Working On My Mobile Phones Trough The Orbi RBK50 Setup. When Tested Only On Provider Modem WiFi WiFi Calling Works Fine On Phones. My Dutch Provider KPN Mobile Tells Me ...
- Dec 21, 2021Thanks for your extra links they have been helpful. I learned that it should let trough IPsec standard and searched onwards to the ISP modem/router. It was set to DMZ for the RBR50 but I noticed that the firewall of the Ziggo Connectbox (ISP router) was still filtering the data. After de-enabling the ipv4 firewall VOWiFi worked. Then I started to re-enable the firewall options one for one and found that the option" block partial damaged IP packages" made the VOWiFi stop. Now all settings firewall are on except the last noted on and everything works fine. Took me about 5 months with the providers of my landline internet and the mobilephone provider and had to sort it out myself.
Dec 21, 2021Guru - Experienced User
I would review the following:
https://kb.netgear.com/966/Troubleshooting-VPN-passthrough-for-home-routers
https://community.netgear.com/t5/Orbi/Port-Forwarding-for-IPsec/m-p/1868492
https://community.netgear.com/t5/Orbi/Orbi-IPSec-VPN-Pass-through/td-p/1632300
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Marcvane86
Dec 21, 2021Aspirant
- FURRYe38Dec 21, 2021Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
