Stigter
Nov 27, 2021Guide
wrong time zone Circle+ (R8000)
Good morning, After a firmware update of my router a did not have history and usage of premium circle. Also the time zone was not correct. I live in the Netherlands and Circle time-zone is 9 hour...
Dec 01, 2021Guru - Experienced User
Is the time zone set correctly on the routers web page? You should be able to change Time zone settings on the routers web page.
I persume DST should be disabled for your region?
Stigter
Dec 01, 2021Guide
The time in the router webpage is correct, all the devices i use are working on the right time zone.
The support website of Circle said that the time zone is taken of the latest admin device. But my devices got the right time zone.
Only Circle have trouble. I assume this is a problem on Circle side.
But do we have to wait another 6 weeks before Circle fix this problem?
