Stigter
Nov 27, 2021Guide
wrong time zone Circle+ (R8000)
Good morning, After a firmware update of my router a did not have history and usage of premium circle. Also the time zone was not correct. I live in the Netherlands and Circle time-zone is 9 hour...
Mkobrien
Dec 30, 2021Aspirant
I had the same problem - my router thought it was March 5, 2019. Log into your router at 192.168.1.1 and navigate to the Advanced tab and then administration menu and then NTP settings menu. Enter an alternative NTP (network time protocol) server address. I used pool.ntp.org and click done. It will take a bit to update but it will get the correct time
- StigterDec 30, 2021GuideSorry,
My router is on the right time zone.
The Circle application is not.
Very disappointing that after a few weeks nothing happened!
