Stigter
Nov 27, 2021Guide
wrong time zone Circle+ (R8000)
Good morning, After a firmware update of my router a did not have history and usage of premium circle. Also the time zone was not correct. I live in the Netherlands and Circle time-zone is 9 hour...
Wrighty_UK
Aug 12, 2022Initiate
Same problem, plus profiles gone and no way to re-active premium.
It seems netgear are not bothered about helping people with this anymore - I have not seen a single acknowledgement of the problem from them, an explanation as to why it happens, or most importantly - a resolution.
Something clearly broke in one of the router firmware updates. It seems nobody at Netgear knows how to fix it, they should just replace the Circle integration with their own netgear parental controls for this router.
