john442
Oct 24, 2018Tutor
Xbox Call of Duty Black Ops 4 INCOMPATIBLE with Circle
The Circle Parental Controls is COMPLETELY INCOMPATBILE with the XBox Call of Duty Black Ops 4 game.
You have to set the filter to NONE or unmanaged device for this game to work. Even at Adul...
john442
Oct 26, 2018Tutor
No one else has this problem???
- DexterJBOct 28, 2018NETGEAR Moderator
Hi john442,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team- john442Nov 01, 2018Tutor
Reply sent
- TheAvoNov 02, 2018Initiate
I am also having this problem.
Blackops 4 will not work when circle is enabled. No filtering or anything, just won't work.
- MflintNov 09, 2018Aspirant
Are you able to post the fix for this on the public forum? I see you sent a message to another user. I am having the same problem with Call of Duty Black Ops 4 being blocked by Circle. Please either post the fix to the forum or send me a message. Thanks.
- john442Nov 10, 2018Tutor
Sadly no. I can't post it because there isn't a fix yet. I am going back and forth with their support, but they haven't even proposed anything yet. (To NetGear support: Please update your website the case page doesn't work with Firefox or Edge browsers--I had to use Chrome to be able to respond)
