john442
Oct 24, 2018Tutor
Xbox Call of Duty Black Ops 4 INCOMPATIBLE with Circle
The Circle Parental Controls is COMPLETELY INCOMPATBILE with the XBox Call of Duty Black Ops 4 game.
You have to set the filter to NONE or unmanaged device for this game to work. Even at Adul...
john442
Oct 26, 2018Tutor
No one else has this problem???
DexterJB
Oct 28, 2018NETGEAR Moderator
Hi john442,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
- john442Nov 01, 2018Tutor
Reply sent
- TheAvoNov 02, 2018Initiate
I am also having this problem.
Blackops 4 will not work when circle is enabled. No filtering or anything, just won't work.
- MflintNov 09, 2018Aspirant
Are you able to post the fix for this on the public forum? I see you sent a message to another user. I am having the same problem with Call of Duty Black Ops 4 being blocked by Circle. Please either post the fix to the forum or send me a message. Thanks.
- john442Nov 10, 2018Tutor
Sadly no. I can't post it because there isn't a fix yet. I am going back and forth with their support, but they haven't even proposed anything yet. (To NetGear support: Please update your website the case page doesn't work with Firefox or Edge browsers--I had to use Chrome to be able to respond)
- john442Nov 16, 2018Tutor
Update, so far they proposed a workaround:
Create a separate profile and configure off time. However, that's not viable as it still doesn't track time spent, just lets me limit it but its too inflexible.
