dawsobr
Nov 20, 2018Follower
XBox still works during bedtime and time limits settings
Hello - I just setup Circle for my home network and all appeared to work as expected. Network devices are being limited as I would expect but my son's Xbox is not being managed quite right with Circ...
DexterJB
Nov 27, 2018NETGEAR Moderator
Hi dawsobr,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
- rlep64Dec 03, 2018Initiate
Hi Dexter -
I'm planning to setup my XBox in a similar way. Could you please post the response?
Thanks,
Rob
- MajorSnarlJul 25, 2019Aspirant
I would like to see the official answer from Netgear as well. I have an Orbi system with Circle Home Plus (not with Disney) and have the same problem with an Xbox session continuing past the bedtime or even a time limit set.
- DexterJBJul 29, 2019NETGEAR Moderator
Hi MajorSnarl, to confirm, you are using a separate hardware for the Circle Home Plus and not the built-in Circle with Disney feature, correct?
Dexter
- ToniBollDec 03, 2018Initiate
Hello - I have my Xbox connected to my Orbi home network. I also have it hard wired because after installing the connection seems choppy - the Xbox games tend to freeze. I LAN connected the Xbox and have a wired connection - was hoping I could use Circle to manage the Xbox but nothing seems to be working. I can see the Xbox and the MAC address matches what is shown in the Xbox settings but no controls (pause, time limits) seem to work. Please advise on how to resolve this - the main reason for my Orbi investment was to manage screen time on the Xbox. THnk you
- leonprMar 19, 2019Aspirant
Two questions for the group:
Does Circle have a way to communicate to my teens the amount of time they are using or have used? Limits seem to 'sneak' up on them. If they can see usage it will help them mangage their online time more efficentily and reduce conflict at my house.
Is it possible to bypass Circle on my Orbi RBK40 and use the wifi without a device showing up in the Orbi app? He has been changing his MAC addresses and that worked until I caught on. I have VPN on Circle turned off but still think he may be using one somehow?
Thanks,
Preston
- DexterJBMar 19, 2019NETGEAR Moderator
Hi Preston,
You can have your kids install the MyCircle app linked below:
Also, the link below may help out.
https://support.meetcircle.com/hc/en-us/articles/115001381931-Stopping-Bypass-Attempts
Dexter
Community Team
