dawsobr
Nov 20, 2018Follower
XBox still works during bedtime and time limits settings
Hello - I just setup Circle for my home network and all appeared to work as expected. Network devices are being limited as I would expect but my son's Xbox is not being managed quite right with Circ...
DexterJB
Nov 27, 2018NETGEAR Moderator
Hi dawsobr,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
rlep64
Dec 03, 2018Initiate
Hi Dexter -
I'm planning to setup my XBox in a similar way. Could you please post the response?
Thanks,
Rob
- MajorSnarlJul 25, 2019Aspirant
I would like to see the official answer from Netgear as well. I have an Orbi system with Circle Home Plus (not with Disney) and have the same problem with an Xbox session continuing past the bedtime or even a time limit set.
- DexterJBJul 29, 2019NETGEAR Moderator
Hi MajorSnarl, to confirm, you are using a separate hardware for the Circle Home Plus and not the built-in Circle with Disney feature, correct?
Dexter
- MajorSnarlJul 29, 2019AspirantCorrect. Circle with Disney is not enabled.
