Mike1567
Jun 21, 2022Guide
“We can’t find your router” message in Nighthawk app- AC1000
The Nighthawk app keeps losing connection with my router. I am trying to check for firmware updates thru the app and can’t check since it can’t find the router. My device is connected to my router and...
- Jun 21, 2022
If you're on iOS, make sure icloud relay and private mac/ip address options are disabled. They can cause issues with the app
Jun 21, 2022Guru - Experienced User
1. what router do you have? AC1000 is a speed, not a model?
2. what modem/gateway do you have?
3. Have you tried manually updating it? I'd recommend doing so over a hardwired connection.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Mike1567
Jun 21, 2022Guide
Hi. Thanks for your response:
Model Number is R6080
Modem - use an ARRIS SB6183
Haven’t tried what you have suggested
- plemansJun 21, 2022Guru - Experienced User
What firmware version are you on?
You can find the firmware versions and the manual here to update
https://www.netgear.com/support/product/R6080.aspx
- Mike1567Jun 21, 2022GuideI was able to update it (look at last reply). The issue now is the nighthawk is again having issues finding the router
