CaptZador
Apr 26, 2019Aspirant
2014 Router update
Can the R 7000 from 2014 still be updated? And is the Nighthawk app Useable on windows 10 with this router?
CaptZador
May 09, 2019Aspirant
Thank you very much for all of your help. I did load a zipped update file to my windows 10, but this machine has no ethernet connection for the older ethernet cables. Any suggestions. was hoping that I could run the update wirelessly to the R 7000 router.
schumaku
May 09, 2019Guru - Experienced User
So what does stop you from doing the update via the wireless connection? USB 2.0 to Fast Ethernet and USB 3.x to Gigabit Ethernet adapters are in the market for a few dollars if it has to be a wired connection.
The App would do the very same, or do you have Ethernet adapters for your mobile devices?
