srh50
Aug 19, 2022Follower
5G AC2300
How can I turn off 5g if nit needed?
1 Reply
Sort By
Which Netgear device do you own? AC2300 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
srh50 wrote:
How can I turn off 5g if nit needed?Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings or something similar. Not all devices are the same.
