Shellbell75
Mar 01, 2017Follower
Ac 1200-cannot Connect to pc
I recently switched to this router. All of my other devices will connect no problem, but I can't get my pc to. It recognizes it but will not connect, says there is no valid IP address. How do I fix th...
William10a
Mar 05, 2017Master
Shellbell75 wrote:
I recently switched to this router. All of my other devices will connect no problem, but I can't get my pc to. It recognizes it but will not connect, says there is no valid IP address. How do I fix this without a hammer lol
You say your other devices connect how do they connect ? Your pc that says there no valid IP Address how it connected and what os is on it?
Now the a important question which ac1200 device are you using and model number would help?
Have you reset the wifi or lan port on the pc to tell about the new router?
- aalexandrebetaMar 06, 2017Master
Explain better your situation, if not we will have issues understanding your problems!
Regards!
