Shellbell75
Mar 01, 2017Follower
Ac 1200-cannot Connect to pc
I recently switched to this router. All of my other devices will connect no problem, but I can't get my pc to. It recognizes it but will not connect, says there is no valid IP address. How do I fix th...
William10a
Mar 05, 2017Master
Shellbell75 wrote:
I recently switched to this router. All of my other devices will connect no problem, but I can't get my pc to. It recognizes it but will not connect, says there is no valid IP address. How do I fix this without a hammer lol
You say your other devices connect how do they connect ? Your pc that says there no valid IP Address how it connected and what os is on it?
Now the a important question which ac1200 device are you using and model number would help?
Have you reset the wifi or lan port on the pc to tell about the new router?
aalexandrebeta
Mar 06, 2017Master
Explain better your situation, if not we will have issues understanding your problems!
Regards!
