stestardi's avatar
stestardi
AC1450 Remote Access
Does Genie support remote access of the AC1450?  Even though the AC1450 is listed as one of the supported devices here, I do not see the option to log in remotely on Desktop Genie as described in Step 3 here, and when I try to enable Remote Access on the iOS Genie I get "This router does not support remote access".
  • Hi stestardi,
    As it stands, the AC1450 is not yet supported by the Remote Login feature of the Genie app.
    Dexter
    Community Team
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi stestardi,
    Dexter
    Community Team
