Mike4678
Apr 12, 2018Aspirant
AC1750 - Genie Parental Control Fails Checking Firmware, OpenDDS working. Wifi Not, Cannot Disable
Hi, Scan topics and have not found solution. AC1750 and Genie Issue, Win10 Pro, Enabled Parental Controls, created OpenDNS and appears all appeared well execept WIFI devices not accessing intern...
michaelkenward
Apr 13, 2018Guru - Experienced User
Are you still looking for ideas?
If so, can you boil it down to a simple point or two?
Something like "My wifi doesn't work".
I gather that your model number is R6400. (AC1750 is a wifi speed, not a model number.) But at the start you say that the firmware version is V1.0.1.38_1.0.25. The latest firmware for the R6400 is R6400-V1.0.1.36_1.0.25.chk
R6400 Firmware Version 1.0.1.36 | Answer | NETGEAR Support
That's the one you mention later.
It isn't clear to me if you have factory reset the thing. If you do reset DO NOT RESTORE A BACKUP unless you have confirmed that it does not revive whatever fault you are seeing.
Mike4678
Apr 16, 2018Aspirant
Sorry, fat fingers.. yes .36 firmware, R6400.
Sure, open to ideas that allow Genie to work even though i can simply create a OpenDNS account, set DNS primary and secondary on router and devices point to OpenDNS.
1) Wifi based PCs not accessing Internet after enabling parental controls / OpenDNS
1) Genie on Win 10 will not identify router preventing further use even though other menu items retrieve data from router.
2) When selecting Parental Controls in order to disable Parental Control to Reset DNS back to internet provider defaults, Genie fails while checking firmware.
