ricktig
Apr 06, 2021Follower
AC1750 R6400 - Nighthawk Android app won't log in after factory reset
Factory reset router due to cable company issue. The router hadn't been reset for several years and was working fine before the issue. It connects to the cable modem now and passes internet traffic...
Christian_R
Apr 12, 2021NETGEAR Employee Retired
Hello ricktig,
May you reinstall the Nighthawk app and let us know if that helps.
Christian
