jvlasvel's avatar
jvlasvel
Follower
Oct 09, 2023
Access Anywhere does not work
App will only do local connection making it useless. No option to remote connect comes up. Router is MR60
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which App? Android?IoS?
    Have you created a link to MyNetgear.
    What happens when you click on the device in the App?
    > Settings
    > Anywhere Access
    By the way, a local connection is not useless. I use it all the time.
