AX8
May 20, 2022Aspirant
Access control RAX70 router
Trying to use the Access Control on the router login page and i get this message when i go to it Access Control To use Access Control, please use the Nighthawk APP. anyone else see this bef...
May 20, 2022Guru - Experienced User
Can you post a screen capture of what your seeing?
I believe NG is moving access controls to the NH app and using Smart Parental Controls as UI for this.
