AX8
May 20, 2022Aspirant
Access control RAX70 router
Trying to use the Access Control on the router login page and i get this message when i go to it Access Control To use Access Control, please use the Nighthawk APP. anyone else see this bef...
May 20, 2022Guru - Experienced User
Can you post a screen capture of what your seeing?
I believe NG is moving access controls to the NH app and using Smart Parental Controls as UI for this.
AX8
- FURRYe38May 20, 2022Guru - Experienced User
I would review this and see if SPC appears on the NH app as a menu tile or get it to appear:
- AX8May 20, 2022Aspirant
This is for Smart Parental controls that is one that i dont want active and im asking about access control
So i guess there is no answer for this
- CD_router_888Jun 08, 2022Guide
AX8 It seems you're already activate the SPC first, you need to wait to the SPC trial expired then you can use the access control.
