Hempierre
Mar 05, 2024Tutor
Access to the settings of my RAX120 Nighthawk via the Nighthawk app.
Good morning, Until recently, I had access to the settings of my RAX120 Nighthawk via the Nighthawk mobile application (current version 2.33.0.269 firmware: v1.2.9.52) outside of my local network. ...
michaelkenward
Mar 05, 2024Guru - Experienced User
Hempierre wrote:
Recently, when I am on another network or 4G the connection is no longer possible even though the 'Activate access anywhere' cursor is green.
What happens when you try?
What messages do you see?
iOS or Android?
- HempierreMar 05, 2024Tutor
it's on ios
RAX120
locally connected (connecté localement in french)
Before I had 2 options: localy and internet (I don't remember the exact word)
- HempierreMar 10, 2024TutorUp
- FURRYe38Mar 21, 2024Guru - Experienced User
Any progress on this?
Anywhere Access is the feature that should be seen and enabled with in the NH app. Look under Settings.
Hempierre wrote:
it's on ios
RAX120
- HempierreMar 21, 2024Tutor
.Hello
"Anywhere access" is always green and I have only local access
