Hempierre
Mar 05, 2024Tutor
Access to the settings of my RAX120 Nighthawk via the Nighthawk app.
Good morning, Until recently, I had access to the settings of my RAX120 Nighthawk via the Nighthawk mobile application (current version 2.33.0.269 firmware: v1.2.9.52) outside of my local network. ...
Mar 21, 2024Guru - Experienced User
Any progress on this?
Anywhere Access is the feature that should be seen and enabled with in the NH app. Look under Settings.
Hempierre wrote:
it's on ios
RAX120
locally connected (connecté localement in french)
Before I had 2 options: localy and internet (I don't remember the exact word)
Hempierre
Mar 21, 2024Tutor
.Hello
"Anywhere access" is always green and I have only local access
- FURRYe38Mar 21, 2024Guru - Experienced User
And if you disable AA in the NH app while your at home with the router and your mobile device, exit the app, then relaunch the app, then go back in and re-enabled Anywhere Access, then navigate back to see if you get the AA entry in the list of devices in the app?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message- FURRYe38Oct 24, 2024Guru - Experienced User
Did this not work?
