Hempierre
Mar 05, 2024Tutor
Access to the settings of my RAX120 Nighthawk via the Nighthawk app.
Good morning, Until recently, I had access to the settings of my RAX120 Nighthawk via the Nighthawk mobile application (current version 2.33.0.269 firmware: v1.2.9.52) outside of my local network. ...
JoseMM
Oct 24, 2024Aspirant
Same problem a lot of time ago. I tried to re enable anywhere access in the app and restart router, I tried to reset router but nothing worked. I need to connect outside because is the router forma my business.
I had two netgear, at home r7000 and business rax120. When i tried to connect to rax120 get an screen telling detecting product and when i click connect anywhere access it keeps connecting to r7000, never rax120
Any other thing to try? thank you very much
- HempierreOct 24, 2024TutorHello, the solution is quite simple, you have to wait a few weeks and the problem is solved without doing anything. The problem certainly comes from them. You will see one day you will find normal operation by miracle. I have never had a technical answer that allowed me to solve this quickly.
- JoseMMOct 24, 2024Aspirant
Hello, thank you for your answer Hempierre.
I have already wait few weeks and didnt work. With the other router r7000 same thing happened until they update firmware.
Long time ago I cant remote manage via web or app my router, and have to wait for a miracle to get it?
Ok thank you Netgear
