Hempierre
Mar 05, 2024Tutor
Access to the settings of my RAX120 Nighthawk via the Nighthawk app.
Good morning, Until recently, I had access to the settings of my RAX120 Nighthawk via the Nighthawk mobile application (current version 2.33.0.269 firmware: v1.2.9.52) outside of my local network. ...
JoseMM
Oct 24, 2024Aspirant
Same problem a lot of time ago. I tried to re enable anywhere access in the app and restart router, I tried to reset router but nothing worked. I need to connect outside because is the router forma my business.
I had two netgear, at home r7000 and business rax120. When i tried to connect to rax120 get an screen telling detecting product and when i click connect anywhere access it keeps connecting to r7000, never rax120
Any other thing to try? thank you very much
Hempierre
Oct 24, 2024Tutor
Hello, the solution is quite simple, you have to wait a few weeks and the problem is solved without doing anything. The problem certainly comes from them. You will see one day you will find normal operation by miracle. I have never had a technical answer that allowed me to solve this quickly.
- JoseMMOct 24, 2024Aspirant
Hello, thank you for your answer Hempierre.
I have already wait few weeks and didnt work. With the other router r7000 same thing happened until they update firmware.
Long time ago I cant remote manage via web or app my router, and have to wait for a miracle to get it?
Ok thank you Netgear
