Hempierre
Mar 05, 2024Tutor
Access to the settings of my RAX120 Nighthawk via the Nighthawk app.
Good morning, Until recently, I had access to the settings of my RAX120 Nighthawk via the Nighthawk mobile application (current version 2.33.0.269 firmware: v1.2.9.52) outside of my local network. ...
Hempierre
Oct 24, 2024Tutor
Hello, the solution is quite simple, you have to wait a few weeks and the problem is solved without doing anything. The problem certainly comes from them. You will see one day you will find normal operation by miracle. I have never had a technical answer that allowed me to solve this quickly.
JoseMM
Oct 24, 2024Aspirant
Hello, thank you for your answer Hempierre.
I have already wait few weeks and didnt work. With the other router r7000 same thing happened until they update firmware.
Long time ago I cant remote manage via web or app my router, and have to wait for a miracle to get it?
Ok thank you Netgear
