ShaKAshA
Oct 21, 2023Aspirant
Add modem to Access Anywhere by IP Address?
Do I have to be on the local network to add a device to Access Anywhere? I am remote and have the ip address of the CAX30 modem and I'd like to add it to my app.
- Oct 22, 2023
My memory is that you may need to be on the local network when you set up Anywhere Access.
How do I enable or disable Anywhere Access on my NETGEAR or Orbi router? - NETGEAR Support
After that you can use Anywhere Access on any number of mobile clients as long as you have the login credentials.
You can also connect to a pile of Netgear devices. I have two Androids that can talk to a two routers (and an AP mode router) on different Internet accounts. The routers will need to be on the same MyNetgear "cloud" service.
michaelkenward
Oct 22, 2023Guru - Experienced User
