ecm4runner's avatar
ecm4runner
add second routers on seperate network to netgear app
I have 2 Seprate network in my home and want to manage both from the same app (on ipad). Is it possible to have both? when I tried to add the second it wanted to replace the first.   Thank you Mi...
  • ecm4runner's avatar
    ecm4runner
    Apr 13, 2020
    Thanks for the reply. Yes 2 different ISPs. I use one for my computers and the other just for home smart devices.
    I actually solved the issue. I had a brain dump, I just needed to connect my iPad to the that SSID then when I open the app IT has the configuration for that router... duh! LOL :)
